Old 10-25-2005, 08:26 PM
minimonster17 minimonster17 is offline
Brake Problem?
Oftentimes, when I am driving, the P!
brake light will stay aglow in the gauge area. Is this indicative of a possible problem? My brakes work fine, though.
Old 10-26-2005, 12:20 AM
KimMG KimMG is offline
AF - Advisor
Re: Brake Problem?
Yes. Check the fluid level.
Some cars have pad sensors that will ground and cause the light to come on when the pad is worn. I don't know if your car has these sensors.
Old 10-26-2005, 02:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Brake Problem?
Effectively, the light will come on if the braking friction material is worn because the pistons in the calipers/wheel cylinders will extend further to accomodate the worn friction material, and that space above the pistons is filled with brake fluid. This causes the level in the master cylinder to lower and the light in the instrument cluster to illuminate.
-Rod
Old 10-26-2005, 09:33 PM
68convert 68convert is offline
Re: Brake Problem?
Try pulling the release handle while pulling up on the e brake pedal. More often than not it's the position sensor on the brake pedal.
Tony
Old 11-01-2005, 11:12 PM
Smile
It turned out tobe the pads after all... I put new ones in today, and things are much better... The light isnt on anymore, BTW.
