Old 10-25-2005, 07:13 PM
avw0516 avw0516 is offline
Send a message via AIM to avw0516 Send a message via Yahoo to avw0516
Biggest Injectors a 190 can support?
As the title states I want to know what the biggest size fuel injector I can run on a walbro 190. I'm getting a dsmLINK and Delphi 950cc fuel injectors to support my rs49 thats in my passenger seat . And I need to know what my walbro 190 can support or if I need to switch to a 255hp and a fpr? Thanks guys.
-Andrew
Old 10-25-2005, 09:16 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Biggest Injectors a 190 can support?
For a 50 trim you will need larger than a 190 pump, regardless of what injectors you run. Injectors and pump are completely independant of each other and each need to be able to support the airflow you intend to run. There is no question that a 190 can't do it at maximum airflow and "normal" AFR settings.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I thought the max, or best flow you would get from a 190 is from 650's. Maybe I am wrong but I am pretty sure that is correct.
hehe also, if you decide to upgrade to a 255, I have one for sale, brand new never used.
1991 GSX 2.3 Stroker
Old 10-25-2005, 09:21 PM
AF - Advisor
A pumps flow depends entirely on voltage, pressure, and restriction (lines, filter, etc). Assuming the pump is rewired, and 99.9% of poeple use stock feed line parts, voltage and restriction can be held constant. Pressure really should just be set at what the ECU expects it to be, so that is pretty constant too. Injectors play no part in deterimining a pumps flow.
You might be able to say that anyhing over 650s would be overkill on a 190, since the pump wouldnt be able to keep up with them, but it wont hurt at all. With DSMlink, I always recomend going straight to 950s on the first upgrade.
Kevin Jewer
Old 10-26-2005, 08:07 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Biggest Injectors a 190 can support?
And only dropped once.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-26-2005, 04:27 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
So with my evo3 big16g, this winter i am buying bigger injectors so i should go that big? I am also getting DSMlink this winter
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 10-26-2005, 08:04 PM
defiancy's Avatar
Re: Re: Re: Biggest Injectors a 190 can support?
hehehe. nope.
It's still in the damn box it came in.
Old 10-26-2005, 08:41 PM
Honestly, with a 16G 650's should be fine. 950's are overkill for my 50 trim, but I got them cheap and the dsmLink can support them and I have plenty of room to upgrade in the future. My injector duty cycle is going to be very low which is fine, but I could be running smaller injectors. To get back on topic I ordered a walbro 255 today and am going to set it up with the Burschur racing afpr. Thanks guys.
Old 10-27-2005, 07:55 AM
AF - Advisor
You could be running smaller injectors, but since there are NO advntages to smaller injectors and MANY advantages to larger injectors, and the prices are similar, there is no good reason to recomend going smaller. IMO.
Kevin Jewer
