Old 10-25-2005, 07:12 PM
2000redGT 2000redGT is offline
Send a message via Yahoo to 2000redGT
Question Tensioner Pulley
Hello all, I'm new to this whole forum! I figured other owners could help me out better than my local dealership. Here's my issue: My 2000 Grand Am GT destroyed it's tensioner pulley. By destroy, I mean the center of the pulley seized and the plastic part had a melt down. So my question is, does anyone have a blow-up schematic of how the pulley goes on? I believe the little metal "bump" on one side should line up with a hole in the block, correct? I'd appreciate ANY help I can get! Thanks all....and maybe I'll be able to help someone else out in the near future!
--Amy
Old 10-26-2005, 06:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Tensioner Pulley
--Amy
You might want to re-post your issue in the Grand Am forum. A lot of sharp Grand Am owners over there to help you.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 10-26-2005, 12:09 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
i posted on ur other post 2000redGT.Dont quite know exactly what ur asking, but the tensioner turns with a 3/8 drive breaker bar in the square hole(turn counterclockwise to loosen the belt). To remove the tensioner, the bolt in the center of the idler , up above the squarehole, is how its removed. I beleive its a metric bolt, 12 or 13mm.
1999 Grand Am SS 3.4 OHV
Old 10-26-2005, 01:03 PM
BNaylor's Avatar
Re: Re: Tensioner Pulley
It was originally posted in the Grand Prix forum and GTPDad moved it to where it belonged.
Thanks GTPDad.
Timeslip 08/12/06
Old 10-26-2005, 01:44 PM
Re: Re: Re: Tensioner Pulley
Thanks GTPDad.
I wasnt aware of the miss placed thread. i meant , their are two posts from 2000redGT, about the same thing, it was just worded differently. and I had posted on both of them, just to make sure.. thanks GTPD
