Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-25-2005, 06:37 PM
telepunk telepunk is offline
Heater not working
I have a 1995 3.8 Trans Sport, all the sudden the front heater won't work, the back one works though
I checked the fuse and its fine, any suggestions?
Old 10-26-2005, 07:34 AM
chris_eitniear's Avatar
chris_eitniear chris_eitniear is offline
Send a message via Yahoo to chris_eitniear
If you're talking about the heater fan not working, you might try tapping on the fan motor to see if it starts up. I just changed the heater fan on a 93 transsport and it was about a 10 minute job. I don't know if the 95 is the same, but it was all easily accessable from under the hood.
Old 10-26-2005, 11:34 AM
Re: Heater not working
A little tap like Fonzie aye? I very little about car repair, but I'll try and find it, got a diagram anywhere?
Old 10-26-2005, 01:16 PM
LMP's Avatar
LMP LMP is offline
Check this out
www.avigex.ca/xport/heater.jpg
www.avigex.ca/xport/heaterrelay.jpg
www.avigex.ca/xport/blowercloseup.jpg
and all of this if you like
www.avigex.ca/xport
YOu can test the blower motor itself by disconnecting the plug at the motor and feeding 12v direct with a pair of wires. If you end up having to change the blower motor, there are 2 types: pressed on fan and bolted on fan. However, if you go to the salvage yard, you can buy the whole unit, motor and fan, and it does not matter which type you use then. BTW, this blower unit is common to oldsmobile, buicks, and bonneville of those years.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
