Old 10-25-2005, 05:05 PM
kmerian kmerian is offline
Send a message via Yahoo to kmerian
Spark plugs?
I am going to do a tune up on my jeep. I was wondering what spark plugs perform the best in the Cherokee. I have an 89 I-6 with 178k on it. Right now I use the Bosch coppers in it, but I have noticed some fouling and build up. Would the platinums help with this?
Old 10-25-2005, 09:37 PM
mrbill3's Avatar
mrbill3 mrbill3 is offline
Re: Spark plugs?
I'll probably get some heat for this, but I only use the Bosch platinum +4 plugs in all of my vehicles. It is the only plug I've used since the day they hit the market. Never had a failure and always get improved performance and mileage.
Old 10-25-2005, 10:19 PM
vamc's Avatar
vamc vamc is offline
Re: Spark plugs?
I dont like the bosh +4. i will not give you any heat on that, just a difference of opinion.Champion is what i use and its fine. but by all means, try a few different plugs till it frun good.
Old 10-27-2005, 04:53 PM
Dominic240 Dominic240 is offline
I would stick to a factory plug.
You say that there is build up on the plugs. this may not be a plug problem you may be running to rich on the fuel side or not enough air.
Seem like that there is too much carbon in there.
You might want to check your O2 sensor.
Also check your cap, rotor and wires. These also could be causing
improper detonation. In which will also cause build up...
Old 11-02-2005, 04:47 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Spark plugs?
I have used a Bosch, but switched back to the Champion. Most mechanics that work on XJ with the 4.0L will tell you they run best on the factory Champ or the truck Champ. The Bosch don't work and they cost more.
Old 11-02-2005, 12:40 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
What I like about the +4 is that it's almost impossible to foul the plug. Does your jeep smoke at all? I would make sure to do the wires, cap and rotor as well as the plugs.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 11-02-2005, 02:03 PM
Re: Spark plugs?
No, it does not smoke. I have just noticed some fouling when I pull the plugs, not a lot. Just thought it was because I was using the cheap-o's
Old 11-16-2005, 06:35 PM
raeuspius raeuspius is offline
Believe it or not, most I-6 yrs. 86-89 have motorcraft Distributors a.k.a. Ford.. Motocraft plugs work well in my Jeep. Lots of Ford electronics as well on our Jeeps. go figure
Old 11-17-2005, 03:06 PM
FORD = Fix Or Repair Daily
FORD = Fucker Only Runs Downhill
FORD = Fucked Over Rebuilt Dodge
1995 Jeep Wrangler
4.5L stroked I-6
Jet Chip Stage 2
Jet Thermostat
Old 11-17-2005, 09:52 PM
vamc's Avatar
Re: Spark plugs?
Lol
