| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Where should ii mount the amp and my fuse block?
ya i got my new amp (profile ap1200) its pretty dam long
should mount it on a piece of wood, or should i mount it on the spare tire coverthing? where can i mount my fuse block (i dont have any wire to spare)so i need it as close as i can get to the firewall, where is a safe place to mount the fuse block? my car is a 97 lumina i dont have alot of wire to spare |
I would recomend mounting the amp to a piece of wood or some other non-conducting material to avoid ground loops, and mount that to your trunk. As far as the fuse block goes, find a good spot with nothing behind it and drill some holes. You could also use some high strength double sided tape or velcro.
Re: Where should ii mount the amp and my fuse block?
well ya i just dunno if under the wipers if theres anything behind it, theres some screws there and some stuff that holds stuff up (heres one, holding the wire loom)
http://img381.imageshack.us/my.php?i...allhole7xd.jpg any one know anystores where i can get the carpet that you would use on a speaker box or car? (local stores, not online) |
That looks like a great spot to mount it. As far as the carpet goes, you could checkany car audio store. Home Depot might even carry something you could use. If all else fails...astoturf
k so there shouldnt be much any thing there right? theres like 2 things mounted on it
does anyone know what local stores would sell carpet that i can use on a piece of wood? (carpet that can be found in the trunks of cars and on speaker boxes and stuff) Last edited by Bboy_Jon; 10-26-2005 at 01:47 AM. |
wal mart sells carpet, that's where i got the carpet for my box. i don't know if you want an exact match, at wally world it's like a big roll for 7 bucks
dam iw as just there to buy my amp kit, i looked around automotive and didnt see any carpet
what section/area is the carpet at? do i HAVE to mount my fuse block? 14 feet of wire isnt enough and i can barely get enough wire to the trunk, if i DONT mount it, the wire that has the ring terminal already on it is too small and cannot reach anywhere that can take the fuse block without losing too much wire so is it needed? and also could i use like a smaller wire (as in 8 gauge) to go to the fuse block, and then from the fuse block comes 5 gauge to the amp? cuz i need all the 5 gauge i can get Last edited by Bboy_Jon; 10-26-2005 at 05:00 PM. |
What does your fuse block look like? Make sure your fuse is as close to the battery as you can get it because the wire before the fuse won't be protected. My fuse is in the engine compartment in an area where it doesn't get in the way of anything. It's not mounted anywhere and is very easy to access in case it ever blew.
'87 Chrysler NewYorker -------------------------- 2 12" Ascendant Audio Assasins in Sealed Box Hifonics TXi 6406 Bridged to 2 Channels VR3 CD/MP3 Player COMING SOON: Component Set Amp for components |
http://i.walmart.com/i/p/00/03/39/91...18_500X500.jpg
next to the ground wire except theres is not holes there to mount it itll be in the same position as my current fuse is (its a atc) it just hangs there would it work if i use both the 8 gauge i have now and a 9 gauge wire for my ground? put both of them in the amp and connect them to the same bolt? |
the carpet is by the steering wheel covers and floor mats and stuff like that.
ill have to check again then, i didnt see any when i looked, i guess i missed it or its not there
Yeah that fuse doesn't need to be mounted it can just be hanging out in the engine compartment.
I've never seen carpet at Wal-Mart either. I asked someone and they said they didn't carry it. Must be the big ones only.
well i have 3 walmarts lol one is super walmart
if i dont see any at my closeer walmart then ill hit up Oreillys, they should have some shouldnt they? |
