Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-25-2005, 03:11 PM
goatg2002 goatg2002 is offline
Fuel Pump Removal
I have a 94 Jimmy and I dropped the tank but cant get the lock ring off. Do I try to turn the outer ring or inner ring and which way do I turn it? Also there are tabs on the inner ring. Do I have to bend those in?
Old 10-26-2005, 07:45 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Fuel Pump Removal
use a hammer and a flat head screw driver... Hit the tabs sticking up from the side counter clockwise.... It will unlock after a couple of inches... install in reverse...
Old 10-26-2005, 09:54 AM
ChrisGood's Avatar
ChrisGood ChrisGood is offline
you know, i always heard that with stingy metal items a blow torch will soften them right up....
warning do not try this
I can fix anything, if you just tell me how.
White 2006 Chrysler Town & Country
Zurich Pearl White 1993 3000GT VR4
1993 3000GT VR4
Old 10-29-2005, 04:40 PM
1995JimmyLT 1995JimmyLT is offline
The screwdriver will work, but I would suggest if you have a piece of brass, a brass punch preferrably, it would be better to use. You'll want to avoid sparks. Just be careful with it either way.
Old 10-29-2005, 06:55 PM
drdd's Avatar
drdd drdd is offline
Sparky McBang says, "better bang with brass" !
