Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-25-2005, 03:05 PM
dgh dgh is offline
1995 Jimmy intermitent starting
My 95 Jimmy sometimes won't start unless I squirt gas or starting fluid in the intake manifold! It will then start and run great! It doesn't do it all the time,however, it has become more frequent! When it starts it runs great! No stalling,good mileage,good throttle response. It only takes a little squirt to get it started! Please help! Wife is getting frustrated!
Old 10-26-2005, 07:47 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 1995 Jimmy intermitent starting
Either failing CPI or failing fuel pump.... First order of business is to check your fuel pressure... 56-60 w/ key in run position, 61-64 with engine started... With the key in the run position, turn key off... Pressure should be maintained for at least 15 minutes before decreasing. If it drops off quicker than that more than likely a bad fuel pump... If not, pull your upper plenum and check for signs of washing.
