Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 10-25-2005, 02:28 PM
mr.avenger's Avatar
mr.avenger mr.avenger is offline
Send a message via AIM to mr.avenger
Popping sound!
02 aztec fwd, if you turn the wheel when parked there is a like popping sound, we changed the wheel hub bearing and we changed the strut bearing, it doesnt sound like the tie rod but we think it could be the ball joint... also if you have the car jacked up and then you let it down it will make the same noise, any ideas?... thanks in advance
1995 DODGE AVENGER!
2.0 ltr. DOHC 420-a engine
Shaved door handles
Shaved gas filler tube(mounted in trunk)
Enkei demolisher 16" rims
Primer awaiting paint
Old 02-20-2006, 04:16 PM
crazydriverz crazydriverz is offline
Re: Popping sound!
when you find out what the problem was please post. we are having the same problem.thanks
