Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-25-2005, 02:37 PM
Julioluko Julioluko is offline
Can a lighter underdrive pulley cause bad vibes?
I have a crank shaft pully that is comming apart, and a new one from mitsu costs $125, so i checked up and i can get a lighter performance one for cheaper. But i have heard that lighter crankshaft pulleys will vibrate more because the stock ones designed to be heavy to absorb vibrations caused by the engine. Is this true for the 4g64? anyone had any problems?
1996 Misubishi Eclipse GSX
New school body...Old school 6 Bolt
100% stock, because cars are the worst investment ever.
Old 10-25-2005, 06:54 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Can a lighter underdrive pulley cause bad vibes?
My pulley doesnt cause any vibrations. Actually, now that i think about it, I got my motor mounts and the pulley installed at the same time. It shouldn't though. You're not changing anything really big. No weight change. If anything, I would think a lighter one would make it smoother.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-25-2005, 11:38 PM
I guess what im looking for is has anyone had problems, oh and i have a 6bolt 4g63, not the 4g64 typo. thnks
Old 10-25-2005, 11:57 PM
inatalonIXLR8 inatalonIXLR8 is offline
I have heard that you have to rev the engine slightly to make the power steering work properly when your at a standstill
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 10-26-2005, 12:42 AM
david-b's Avatar
Dave is THAT guy
What?
There is no problem with the power steering at idle. Swaping pulleys don't affect the accessories that much. Alternator will put out a little less juice than the stock pulley, but there will be difference with the power steering. Also, I don't know too many people that turn when not moving.
75 Monte Carlo
Old 10-26-2005, 02:01 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: Can a lighter underdrive pulley cause bad vibes?
What are you talkin about, I sit there and crank on that bitch until I wear holes in my tires. haha
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-26-2005, 10:52 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
[quote=Julioluko] i have heard that lighter crankshaft pulleys will vibrate more because the stock ones designed to be heavy to absorb vibrations caused by the engine. [/QUOTE=Julioluko]
True, don't use lightweight crank pullys. Use New factory Mitsubishi crank pullys. Lightweight pullys are ok for everything else.
DSM geek
Old 10-26-2005, 07:31 PM
ted_ex's Avatar
ted_ex ted_ex is offline
You need a pulley with a harmonic balancer or I think the crank sees to much vibration. I don't really know the specifics but I'd stick with OEM or an aftermarket one with a harmonic balancer.
I'm>everything
Old 10-26-2005, 07:37 PM
david-b's Avatar
Dave is THAT guy
"True, don't use lightweight crank pullys. Use New factory Mitsubishi crank pullys. Lightweight pullys are ok for everything else."
That didn't make sense. Lol. You tell him not to use a lightweight pulley, then you say they're good for everything else. Meaning what? Just asking.
75 Monte Carlo
Old 10-26-2005, 11:05 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
He meant that you shouldn't use lightweight underdrive pulleys because most of them do not have a harmonic balance. But it is all right to use lightweight pullys for everything else.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
