Old 10-25-2005, 01:10 PM
elflamenco elflamenco is offline
91 PA won't start. intermitant
I have checked battery, starter, neutral safety switch and ruled that out. When i turn the key i get no noise. starter does not engage at all. Tried starting it by manually engaging the starter but the car will not stay on. I ruled out any fuel issues since every once in a while the car will start normally and run fine. I have also checked all the fuses and they seem to be fine. Is there anything else i need to look at before i open up the steering column and take a look at the ignition switch?
kind regards
Old 10-25-2005, 04:55 PM
maxwedge maxwedge is offline
A990 racer
Re: 91 PA won't start. intermitant
Any kind of security system, a/m or factory?
Old 10-26-2005, 03:32 PM
I did notice that the security light stays on. could that be the problem? could there be a problem with the key itself?
anything would help
Old 10-26-2005, 04:39 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Sounds like a VATS problem. This link should help.
http://www.motorage.com/motorage/dat...09/article.pdf
VATS & PASSKEY 11 systems
