Venture gas smell
I have a 1998 Venture with 98k miles. It has been relatively trouble free until lateley. The Intake maniford gaskets started to leak. I replaced them at about 88k miles and all was well until my wife began noticing a strong gas smell about 80% of the time just after the car is shut down. There is no apparent leak. The smell is generally at the front left of the car. It dissapates after a few minutes. I am also getting an intermittent check engine light. I suspect either leaky injector nozzle or something related to this, perhaps a failing evaporative canister. The car always starts and runs flawlessly. Has anyone seen similar symptoms or have any ideas? I have searched this forum and have not seen anything similar. I'm also reluctant to send it to a dealer.
Thanks, |
Re: Venture gas smell
Well what does the code say?
Vinyl adds horsepower, right? |
I experienced a similar situation to yours recently, where I smelled gas but couldn't pinpoint a leak anywheres. It wasn't until I took my van in for exhaust work that they told me they found a leak in the fuel line in the area under the driver's side seat. There appears to be a flat metal piece that comes off the floorboard and the fuel line on my van passes through this piece of metal. The leak just started before it entered the metal. It was a quick fix with some compression fittings and a new piece of line. The leak was very small and hard to see. I live in NY where there is a lot of salt used on the roads in the winter, so we constantly have problems with brake and fuel lines rusting out. That might be something to go back over and check, also check the fittings on your fuel filter, and the condition of your fuel lines.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Re: Re: Venture gas smell
P0305 - Cylinder 5 misfire detected P0440 - Evaporative emission control system malfunction P1676 - Driver 4 Line 6 (which I believe is related to an evaportive emission control problem Does give enough information to zero in on the problem? |
Re: Re: Re: Venture gas smell
Deny |
p1676 is the evap purge control solenoid code. Sounds to me like you have a bad purge solenoid. This would cause a gasoline odor because the system can't vent any vapors into the engine. I assume you have a 3400 engine. I believe the purge solenoid is located behind and under the coil packs. If all vacuum hoses and wires look ok, i'd bet it's bad.. This doesn't seem to be a fuel system problem..
DenyP |
