Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-25-2005, 10:49 AM
street_shark_20's Avatar
street_shark_20 street_shark_20 is offline
Thumbs down 95 integra clutch problem!
I put a new clutch on my b18b, and when i had it on the lift, it would engage all the gears. I backed it out of the bay, and when i put it in first and let the clutch out....nothing happened! None of the gears engage. Reverse makes a whining noise. Help would be appreciated!!
Old 10-25-2005, 01:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: 95 integra clutch problem!
did you guys bleed the air out of the slave cylinder ?
Team Lonely Drivers
Old 10-25-2005, 01:51 PM
Yeah, we bled the cylinder. A couple times too, but with no luck. The clutch goes in and out on its own, but the gears just dont engage. Thanks.
Old 10-25-2005, 04:12 PM
r u sure the clutch is working. can you shift it with the car off ? r u only trying to shift it with the car on ?
Team Lonely Drivers
Old 10-25-2005, 04:15 PM
I cant really tell if it goes into gear with the car off because i have a short shifter. But i know it doesnt go into reverse with the car off, i can feel that.
Old 10-25-2005, 04:24 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Is the clutch facing the right way? Most of them have a front and a back. Did you get any grease or oil or anything similar on any of the parts?
Old 10-25-2005, 05:07 PM
i am pretty sure the clutch is in the right way, and i didnt put grease on anything but the pilot bearing.
Old 10-26-2005, 08:16 PM
Well, assuming you didn't fondle the flywheel or disk with greasy/oily hands, its not slipping. Which leads to other problems. Are you using honda parts, are you mixing parts from different manufactureres, did you get a honda flywheel resurfaced?
When you say it engaged on the lift, you mean the wheels spun? The trans should always shift unless you've done something to the internals. And the wheels will spin in neutral on a lift, just not really fast. If that's what you saw then it wasn't engaging at all, and you've got a tolerance issue. This can be caused by something as stupid as getting the wrong throw out bearing, even one thats off just .015" can make a clutch not release right.
Old 10-27-2005, 06:32 PM
it went in gear on the lift, the wheels spun in 1st and reverse. I backed out just fine, but when i put it in 1st to pull away, that was all she wrote! Like you said, i bet its something stupid like the bearing or something, but i broke down and am taking it to my mechanic to check it out. I'll let you guys know whats up. Thanks!
Old 10-27-2005, 09:07 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
i say u just take it back apart....maybe ur axles aren't in all the way...or u broke one....maybe that tranny was shot, or your pilot bearing came out.....
Old 10-29-2005, 08:48 PM
you've got to be kidding me! It did turn out to be the damn axle that popped out. I popped it back in and have since been enjoying spinning tires in third gear! Thanks for your help.
