Old 10-25-2005, 09:45 AM
raider77 raider77 is offline
Service 4wd indicator, 99 silverado
Hello, Chevy World !
Im looking for advice on possible solutions for the service 4wd indicator which comes on periodically on my 99 silverado, I have no problem engaging into or out of 4wd. spoke with the dealers mech. and they were no help, Has anybody had this problem with the light on the message center ??
Old 10-25-2005, 11:34 AM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
sorry I can't be much help, but I've got an '02 and i didn't even know there was a service 4WD indicator. Never seen it or heard of it. You might check your owners manual and see if there is a way to reset this indicator yourself kind of like how you reset your oil change indicator.
Old 10-25-2005, 02:32 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Service 4wd indicator, 99 silverado
The 4wd switch needs replacing, or fixing. I replaced mine 3 years ago and the light went off.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-25-2005, 03:59 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Re: Service 4wd indicator, 99 silverado
ya the 4wd switch either needs replaced, or you can just pull the switch out and take cleaner made for thoes parts and clean it. I herd of some people doing that and it works.
Old 10-25-2005, 06:49 PM
Im going to take the switch out my self, and try that method first, i`ll let you all know what i find out thanks to all. Later!
Old 10-25-2005, 06:51 PM
I`ll be on vac. for a week, check with you all when i return.
Old 10-26-2005, 07:00 AM
redneck45 redneck45 is offline
I pulled my switch out and tried cleaning it and checking for cracked soldering, then when I put it back in the lights would not work. $40 and I got a new switch from a buddy at the garage. No problems since!
Old 10-30-2005, 12:12 PM
catriple catriple is offline
I have the same problem with the light coming on periodically in a 1999 sportside. After having it looked at and the differentials flushed, this can be the only solution. Can anyone point me to where the switch is located? I'd like to do it myself. Thanks for the help!
Old 10-30-2005, 01:34 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
It's the switch to the left of the speedometer that lets you select 2/4/hi/low etc. Cleaning it if it's cracked won't help...just resolder the wire joints...there's like ten of them. It's real easy to remove and repair...I did mine.
Old 10-30-2005, 02:02 PM
Thumbs up Re: Service 4wd indicator, 99 silverado
Thanks Sonny01. I am going to do it right now! Ill keep everyone posted.
Old 10-31-2005, 06:12 AM
I just made mine worse by taking it apart. Could not see where there were any solder joints, if there were they were very small and putting a solderin iron to them would just melt the circuit board.
Old 10-31-2005, 08:02 PM
I ended up repacing the unit for $62.00 and now everything is perfect! Thanks for everyones help!
Old 10-31-2005, 08:49 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What transfer case 246 or 261?
Before throwing parts at it get it on a eng/tran capable bidirectional scanner and check for codes and check transfer case operation.
They are computer controled just like the engine
The scanner will help work/check out things.
Post back transfer case and any codes you get.
MT-2500
Old 11-01-2005, 12:03 PM
hello everyone just got back in from vacation, (which was great) i had the switch replaced before my trip at a cost of 162 $$ . have not had the light come on since, if it ever comes on again i will replace it myself. thanks every one for the help!!
Old 07-12-2007, 01:40 PM
dan clark dan clark is offline
how do you get the switch out ? how do you remove the dash
