Old 10-25-2005, 09:22 AM
atchisbr atchisbr is offline
Exhaust Smell when Heater On
Good morning All....
My wife reports that when she turns the heater during her morning commute she smells 'fuel' or 'exhaust fumes' in the cabin. She said it gets to bad that she has to crack the windows to ventilate.
I drove the car around last night with the heater blowing and didn't smell a thing.
Any ideas? Could it be something that only happens when the car is started in the morning after sitting all night? It is not cold here in the mornings yet (mid 40's).
Feedback appreciated
Old 10-25-2005, 11:36 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Exhaust Smell when Heater On
It is possible that you have an exhaust leak that is opening up when the car sits and gets completely cold. If it is a fuel smell there is a possibility that there may be a fuel leak but that should be easy to find if you open the hood and start the car. Check all the fuel connections. You may also be able to find something in the form of smoke or vapor coming from the exhaust as well.
The other possibility is that the wind is blowing from the back of the car causing the odor to enter the car. Good Luck!
Old 10-25-2005, 01:09 PM
Thanks! I will check all of those things tonight as well as tomorrow morning when the engine is cold.
Old 10-25-2005, 02:41 PM
PotIsYourFriend PotIsYourFriend is offline
atchisbr, has the car been worked on lately? I'm only asking because I had to have my fuel pump replaced and the mechanic didn't get the hose on the fuel tank on right and leaked everytime I filled up and I could smell gas all the time...
Old 10-25-2005, 03:15 PM
PotIsYourFriend...
Thanks for the reply. No, the car has been trouble free (fingers crossed) for quite a while now...no trips to the doctor.
Any other ideas?
Old 10-25-2005, 09:55 PM
vamc's Avatar
vamc vamc is offline
The M.D can diganose the prob..tell them to do a "cbc chem 7" and do a Physical. with the cbc chem.7, the lab can determine what is wrong.
In english....have a code scanner on it and se if everything is working fine.
Andrew RP.H
Old 10-25-2005, 09:56 PM
vamc's Avatar
You know...i heard that a bad cat. could make this smell. Anybody heard this before?
Old 10-27-2005, 05:30 PM
Re: Re: Exhaust Smell when Heater On
I could see that.. It does collect deposits then over time they combust.. Heck the exhaust can even smell like unburned gas too.......
Old 10-28-2005, 06:13 PM
vamc's Avatar
That is also also true. I agree.
