Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-25-2005, 09:02 AM
T66's Avatar
T66 T66 is offline
Turbo Manifold
Hi Guys. How important is it that all 4 (4 cylinder) channels or ducts are the same length on a Turbo Manifold. The reason I ask is that I saw a HKS Rotary (13b) Turbo Manifold and the one channel was a lot shorter than the other.
English is not my first Language.
Old 10-25-2005, 01:15 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Turbo Manifold
equal length means equal pressue on all cylenders...
Old 10-25-2005, 05:36 PM
CBFryman's Avatar
Banned
Re: Turbo Manifold
exaust back pressure and delta drop that is
Old 10-25-2005, 05:44 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Turbo Manifold
a 13b is a rotary......they don't follow the same rules as everything else......
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-25-2005, 08:40 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Turbo Manifold
Equal length will not make much of a difference at all in power or response. It is only in theory that equal length will increase response. Tubing diameter would be more of a thing to worry about in regards to the characteristics mentioned.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 10-26-2005, 08:07 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Turbo Manifold
really ? so the thing about equal length really helping the engine is a myth ? i always understood that the diameter/flow capacity would be more influential, but with the equal length thing, i thought it would make a great deal of difference to engine, an was always told i was wrong.
Seatbelts Saved My Life
Old 10-26-2005, 07:49 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: Re: Turbo Manifold
Theory works most of the time. How well a theory works depends on how you've misapplied the other theories in close proximity(I just made that up!).
Equal length? On-boost it may not make much of a difference, but off-boost it does.
But then again this thread is about rotarys......
Old 10-27-2005, 01:06 AM
T66's Avatar
T66 T66 is offline
Re: Re: Re: Turbo Manifold
The intention of this thread is to establish whether equal length pluming on an exhaust manifold is the Alfa and omega. This thread is not about rotary’s. I simply used it as an example. Thank you for the info, why would it not be an issue on boost?
Old 10-27-2005, 01:46 AM
2turboimports's Avatar
2turboimports 2turboimports is offline
Re: Turbo Manifold
You asked a question about equal length headers siting the ROTARY engine you saw them on or whatever. That's why everyone is talking about rotary this and that.
I would think it would make a bit of difference on boost since there would be that little bit more flow in the exhaust allowing the air to escape in larger amounts.
Unequal length tubing would have that bit more restriction somewhere which would increase the pressure in the exhaust. Pressure isn't something you really want in the exhaust, it's more flow that you are usually after. There are exceptions though.
But then it also goes back to how long the tubing is, how many bends, etc etc.
Old 10-27-2005, 11:20 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Turbo Manifold
on N/A it matters, harmonics and all that jazz.
on Boost, it doesn't matter.
Old 10-27-2005, 11:26 AM
T66's Avatar
T66 T66 is offline
Re: Turbo Manifold
My first language might not be English but if you read my first sentence you will see my question and the rest of the gentlemen seemed to understand my question. I used the rotary application as an example.
Old 10-27-2005, 11:30 AM
240SX Guy
Re: Turbo Manifold
http://sdsefi.com/techheader.htm
-Cory
12.6@122mph
Old 10-28-2005, 03:33 PM
T66's Avatar
T66 T66 is offline
Re: Turbo Manifold
nissanfanatic, your input is much appreciated.
Old 07-29-2006, 08:14 PM
KiwiBacon KiwiBacon is offline
Re: Turbo Manifold
Equal length keeps the exhaust pulses arriving at regularly spaced intervals.
It's important on a NA engine, it's important on a boosted engine too. But on a boosted engine it's easier to mask shortcuts in design and fabrication by just turning up the boost.
Then you get applications like Subaru. Because of packaging issues you can either have shorter, unequal length pipes or longer, contorted equal length pipes. In a siutuation like this there doesn't appear to be an advantage either way. The longer ones have more volume and more heat loss which offsets the advantage of equal lengths.
BTW some 4 cyl turbo manifolds arrange pipe lengths to combine pulses, rather than equal spacing them.
Old 07-30-2006, 11:08 AM
Schister66's Avatar
AF -Advisor
Re: Turbo Manifold
if you want to start a new thread about this....do it, but don't bring back one that's almost a year old
