Old 10-25-2005, 07:41 AM
czm400r czm400r is offline
Drips? Drips? and more Drips?
Check this out, I have a 99' Blazer with 125K on it that is in super great condition. It has been sitting for about a week, while I drive my other truck. I took it in for an oil change only to be told it is leaking antifreeze twords the rear of the engine. The level was still good so I took it home and parked it with a tray under it.
Well they are correct is is dripping but in like four spots, maybe 1 or 2 drops a day. There is no sign of antifreeze leaking from anywhere I can see in the engine compartment.
Can this be a rear or lower leaks that is puddling up and then runnning to a couple spots to drip. The truck runs great and there was no sign of antifreeze in the oil or anything like that. Any Ideas on where to look, I cannot get to far under the front to see.
I have never had the gaskets or hoses replaced. The shop by me said they can do all of them for about $850 does this sound like it is worth it if they would be replacing gaskets everywhere the cooling system has them.
Old 10-25-2005, 09:50 AM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Since the blazers are known for the intake manifold leaks, it could be leaking back by the distributer and running down the block. Check around the entire manifold. Check your heater hoses from the fire wall to where they end. Check the lower radiator hose. If you cant find a leak in any of these places, maybe you can start it and let it get hot and look for steam. Just some suggestions. Good luck
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 10-25-2005, 02:01 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Drips? Drips? and more Drips?
Check the coolant lines leading to your heater core first. Many times, they will leak at the firewall and drip down the back of the engine. THe cost to fix that is *nothing* if you pop the hoses off and clean the pipes sticking through the firewall, installing them with new screw clamps.
