Old 10-25-2005, 03:02 AM
crfiggins crfiggins is offline
Heater not working...
My heater is blowing out cold air in my 92 3.1 lumina. I am assuming it is the heater core, but not sure. I got the car for free, and the person I got it from said it needed to be flushed for the heat to work again (doesn't make sense to me, but I don't know)...Any way to check if the heater core is out? Or, is there something else I could check also?
Old 10-25-2005, 05:44 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Heater not working...
First open the bleeder(s) on the cooling system and fill it. If coolant is low, or air is trapped, the heater core won't get flow.
Then check the inlet and outlet at the firewall. With the heat on and engine warmed up, they should be about the same temp. If one side is colder, the core is probably hogged up or the heater control valve is broken.
I assume your temp gauge indicates a normal range?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-10-2005, 09:18 PM
colinsdad colinsdad is offline
Where is the petcock on the system?? I noticed there is a notice on the radiator support that say "follow recommendations for filling cooling system" what does that mean?
Old 11-11-2005, 03:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
There are bleeder valves on the engine. One on the T-stat housing, the other on the transfer tube near the water pump. You need to open these valves while re-filling the cooling system to ensure that you get all the air out.
Old 11-12-2005, 07:00 PM
Where is that heater control valve?
Old 11-20-2005, 01:44 AM
Anybody????
Old 11-20-2005, 03:06 AM
Madman762 Madman762 is offline
It would be located somewhere in one of the heater hoses. If you think its not working, try bypassing the valve by splicing the hose together. Anytime you mess with the cooling system, though, keep a close eye on the temperature gauge until you get it properly repaired.
Old 11-22-2005, 10:19 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Could be an air pocket or other blockage in the heat core. Or, the valve that lets coolant into the core may not be working properly.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
