Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-25-2005, 03:08 AM
Ken Harris Ken Harris is offline
Angry Ford Twin I Beam Suspension Ball Joints
Can someone please tell me which ball joint on the twin I beam is the load carrying ball joint? How are they checked?
Old 11-18-2005, 09:16 PM
gbic1 gbic1 is offline
Top ball joint. Your crown vic has twin I beams? LOL. Jack the truck up by the axle and get about 4 inches of clearence under tire. Slide a 2x4 under tire and lift. Have some one else watching the ball joint for movement. For my money if I were to replace one I would do both on that side and then you would have grease fittings.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 11-19-2005, 06:57 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Ford Twin I Beam Suspension Ball Joints
They are BOTH "load carrying" joints.
Old 11-19-2005, 11:43 PM
Yes, they are but usually the top goes out first.
1988 Bronco 351 C6
Old 11-20-2005, 11:44 AM
ModMech's Avatar
Actually, with the "Twin I Beam", the LOWER typically wears out first. With a fleet of E-350s, I am VERY familiar with them.
Old 11-20-2005, 03:05 PM
Not that it matters and not to argue but the I just checked my records and the last 7 fords I did this year all had the top ones bad. Of course these werent all F350s. Some were Explorers and F250 Superdutys. Most were 4x4.
1988 Bronco 351 C6
Old 11-20-2005, 05:49 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I know the 4x4 front ends use ball joints, but all the twin I Beam front ends I worked on (2 wheel drive, up to '88 ) had king pins, not ball joints. Did they change to ball joints in later years?
