Old 10-24-2005, 11:51 PM
dan3233 dan3233 is offline
Send a message via AIM to dan3233
Question Installation of throttle body.
I just got a code 7 the other day for a bad throttle position sensor, so I am planning on replacing the entire throttle body. Does anyone know how difficult it is to do? Any crucial steps I will need to know about? Thanks in advance!
Old 10-25-2005, 12:06 AM
Re: Installation of throttle body.
1988 Honda Civic Hatchback 1.5L
Old 10-25-2005, 01:26 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
you know you could just replace it with another dpfi tps sensor right ?
its alittle bit harder than a mpfi tb change cause if i recall the injectors are on the tb so you need to take them off. idk just take off whatever needs to be taken off
Team Lonely Drivers
Old 10-25-2005, 01:27 AM
Hybrid1990crx's Avatar
i would just replace the tps.
Old 10-25-2005, 02:50 PM
Well I was going to just replace the tps sensor but then I found a throttle body for 70 bucks. So how difficult is it to install the throttle body?
Old 10-25-2005, 06:16 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Re: Re: Installation of throttle body.
For 70 bucks you can buy a MPFI manifold with throttle body, just find another DX TPS at a junk yard and cut grooves into the screw holes and swap it over to yours. It should not cost more than $10.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 10-25-2005, 10:20 PM
How do I get the original tps off.
Old 10-25-2005, 10:56 PM
its screwed on so you need to make slices in the screw and unscrew it. it doesnt look like screw, it looks like rivets or something but its screwed on
Team Lonely Drivers
