Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 10-24-2005, 11:45 PM
tolik412 tolik412 is offline
99 eclipse gs spyder keyless entry
Hey whats up? I'm new to this website, found it through google today... anyway, i bought a 99 eclipse spyder recently and it didnt have a keyless entry remote. I bought one off of e-bay but didn't realize it that it didn't come with programming instructions. I went to the dealer and they told me thirty five buck to program it, theres gotta be a cheaper way, can anyone out there help out?
Old 10-25-2005, 12:01 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
try searching the site for "programming remote" or "keyless entry". I know it has been discusses before. It has somethign to do with a sequence of turning the key from on-ACC-on-ACC and then hitting some buttons on the remote, but I forget. You will find it if you search.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 03-18-2006, 09:30 PM
kevin2006 kevin2006 is offline
Re: 99 eclipse gs spyder keyless entry
i have a 99 gst and i also have the remote but dont know how to pro. it plz someone help me im still searching
i have a 99 gst if someone can plz help me on how to prog, thanks
Old 03-18-2006, 10:17 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
then how about takeing eclipse's advice and searching the site
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 03-19-2006, 12:44 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Ahh... he did this thread is from october.
I'm not sure how to do it, have you checked the owners manual? If you still have it.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-19-2006, 07:56 PM
Check wut i just neeed to know how to prog. my keyless entry i got the remote
Old 03-19-2006, 10:28 PM
The easier way is to let the dealer program it with the ODB-II logger. There is one alternative way, but I never found it.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 03-21-2006, 11:56 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
96-99 uses this method:
To reprogram your keyless entry system for a new key fob:
1) Turn ignition to OFF.
2) Ground pin 1 of the Data Link Connector (black 16-pin connector under dash driver's side). Pin 4 of this connector is a ground, so placing a jumper wire between pins 1 & 4 will accomplish this. Grounding pin 1 tells the system you are getting ready to reprogram it.
3) Close all the doors.
4) Turn the key to ACC, then back to OFF. The power locks will lock/unlock. The system is now ready to be programmed.
5) Press a button on your key fob.
6) If you have two key fobs, press a button on the second fob within 1 minute of pressing a button on the first one. Both must be programmed at the same time. If you only have one remote, press a button on it 2 more times to signal that you only have one.
7) The doors will lock/unlock to signal that the codes were received.
8) Remove the connection between pins 1 & 4.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-23-2006, 07:33 PM
ok guys i did that and i blew the fuse for the door locks
