Old 10-24-2005, 11:42 PM
laser apexi turbo laser apexi turbo is offline
Boost Leak or what?
k so i bought a boost gauge for it today. installed it correctly. ran about.. 10-12 pounds a boost. Then i shimmede the wastegate too add a couple more pounds a pressure and after i was done. took her oput and it was runnin about 13-15 then.. stopped at a redline after a bit of hard drivin and the most it will run if 8 if u hold it otu to redline.... Im thinkin its a boost leak but not 100% sure. if so, how do i test for it? i heard poor soap and water over all the charge pipes. Is that correct?
Old 10-25-2005, 02:10 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
Re: Boost Leak or what?
I forget the exact link but you can buy all the things at home depot or lowe's and make one yourself. Its basically an enclosed piece of rubber with a nipple and you run an air compresor to it and listen for leaks. Try a search on here....... vfaq.com or plymouthlaser.com or dsmtuners.com ... some sites I think sell them..try koumotorsports.com for that
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 10-25-2005, 04:28 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Here is the link to the boost leak tester.... [url=http://www.vfaq.com/mods/ICtester.html] I also put inline a pressure regulator so it will bleed the air in (10 psi)and not just blast 100 psi into your intake system...
Great "must have" item for any boosted car!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 10-26-2005, 04:38 PM
k thanks. one other quiestion is... where exactly do i hook the tester up too??
Old 10-26-2005, 05:18 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
you sure you just didnt heat soak your intercooler? also you sure the wastegate is permanently open now since adjusting it?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 10-26-2005, 05:28 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Its not a leak if you have a 2g with stock bov. please tell us what you have.
DSM geek
Old 10-26-2005, 11:54 PM
i got a 1990 plymouth lasre turbo, with k&n filter and no muff or res. and how do i know if i heatsunk the intercooler?
Old 10-29-2005, 08:40 PM
I found the problem to be directed to the conecting rod from the wastegate to the exhasut manifold thing... the pin at the front fell out and the conecting rod popped off. Thanks for the help htoe guys. much appreciated
Old 10-29-2005, 09:09 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
If its a stock t25, its not gonna hold full boost til redline, only like ~5grand
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
