Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-24-2005, 11:22 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Bad Knock sensor cause Backfire?
Hello all. I was just curious if anyone knew if a bad knock sensor would cause a backfire when accelerating. The knock sensor helps to retard or advance timing, right?
Any thoughts?
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 10-25-2005, 11:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Bad Knock sensor cause Backfire?
The knock sensor sends a signal to the computer to tell it when knock is detected. When the computer gets the signal it retards timing to eliminate the problem. Knock sensors can go bad but it should give you a CEL. Unless timing is being retarded severely a back fire is very unlikely. But you would notice a severe loss of power as well.
