Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 10-24-2005, 09:46 PM
buckroo buckroo is offline
No heat from vents
My daughter has a 2000 Concord that has a problem with emitting hot air. The ac works just fine as does the vent, defrost (but no hot air from the defrost) and recirculating of air but no hot air from the heater. I have checked the fuse and looked for hose that may be loose but have not found any problem. The temp gauge reads normal, half way between cold and hot.
Could someone tell me where to start looking for her problem?
Thanks in advance.
Old 10-24-2005, 09:58 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: No heat from vents
could be a blend door malfunction not allowing the hot air from the heater core to be directed properly.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-24-2005, 11:01 PM
Re: Re: No heat from vents
Would this have to be reached from inside the dash? If so is this a do-it-yourself job? What would I have to remove to get to this blend door?
