Old 10-24-2005, 08:13 PM
tjm17 tjm17 is offline
Heater\AC unit removal
Can anyone help point me in the right direction to remove the heater\ac unit from under the dash. Not sure how many mounting bolts there are inside the engine compartment. Do the heater hoses and ac line need to be removed?
Old 10-25-2005, 04:35 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Heater\AC unit removal
Well if its a 1973 Triumph then you just have to lay on your back and reach up under the dash so you can undo everything.
If its a Lotus Excell you have to start by removing the rear interior panels beside the back seat, then remove the back seat so you can get the centre consul out. Then you should be able to reach up under the dash with the help of a double jointed midget and get access to the assembly.
But with out knowing what car you have its a little hard to be any more specific.
Old 10-26-2005, 02:26 AM
zagrot zagrot is offline
Send a message via Yahoo to zagrot
if you are removing everything completely and the a/c system is charged then your first stop is the a/c shop. tell them that you need the coolant recovered so you can open the system.
Old 10-26-2005, 02:41 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Just put a screw driver in the service port, the environment is fucked anyway.
Old 10-26-2005, 03:10 AM
Moppie's Avatar
Master Connector
Re: Re: Heater\AC unit removal
And we'll dump some nuclear waste into your back yard while we're at shall we?
