i'm new to this forum so thanks in advance for any help. i have a 95 4x4 with about 120000 miles on it. very reliable until recently, old age i guess. the engine cranks but there is no spark from the coil. i replaced the coil, checked the asd relay, and replaced cap, rotors, plugs, and wires when i replaced the fuel pump last year. the check engine light also does not come on when the key is turned. i've researched several threads and i believe it is a sensor problem. not sure how to go about tracking which sensor though. I've also checked the wiring harness under the windshield washer resevoir and the wires are like new. that was identified as a problem in this vehicle.
Re: 95 dakota no spark
what size engine do you have?
go to this web site and use the key on, off method to determine if there are any codes stored in the computer and let me know.
http://minimopar.knizefamily.net/fault/index.html |
reply to no spark
it's the 5.2 8 cylinder.
i'll tyr to get the codes when i get home and let you know. thanks for the website info. |
i checked that website. great info but mainly for 2.2 and 2.4l 4cyl fuel injected engines. there are no reference codes for a crankshaft position sensor problem. is there another site with dakota information? thanks.
I don't know much about Gen2 Dakotas like the one you have. But if you post your question at these forums, there's guys who know a lot about the older Dak.
www.dakotausa.com www.dakota-durango.com |
I would be looking at the pickup coil in the distributor or the crank sensor.
thanks for the help. i'm working on sensors first before i try the pcm. since i have no check engine light to give me codes, i'm waiting for a friend to ehlp pull codes out of the pcm to narrow things down. i'll post when i figure it all out. thanks for the websites, i'll review them also.
i found the problem. there was a corroded splice in the wiring harness under the fuse block in the engine compartment. to narrow it down i found out the following. i had no spark to the coil, no spark to the pickup coil (cam sensor - hall effect same thing), no power thru fuse 13 in the cab, no power to the smec pin 7, and no check engine light. I had to remove all of the tape around the wires, cleaned up the corrosion, and reconnected the wire splice (3 to 1 splice). thanks for all the help.
I havea90' dakota 2.5 that wont start replaced the hall pickup sensor under the dist.cap I get power to the pos.side of coil and fuel pump starts to work for a second when I reconnect the battery or I disconnect computer. it does turnover but no spark to plugs. help I need this fuel squezzer 120 mile round trip to work. thanx
