Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-24-2005, 07:14 PM
Johnnystorm Johnnystorm is offline
Send a message via AIM to Johnnystorm Send a message via MSN to Johnnystorm Send a message via Yahoo to Johnnystorm
Unhappy blower motor problem
once you plug the power back up it should just work right??? my old one would blow whenever it felt like it so i took it to the dealer and they said the blower motor was going bad and i could install it and replace it. so i just took it out and put the new one in and plugged it up and i get nothing now nothing at all what to do??? do i have a bad blower motor???
Old 10-27-2005, 09:38 AM
nemets88's Avatar
nemets88 nemets88 is offline
you could possibly have a bad motor...also i would check the connection to make sure it is secure and is definately not the problem...i would also check the wiring to the motor
Old 10-28-2005, 10:31 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: blower motor problem
could be a bad blower motor resistor. It's an electrical resistor that varies the speed of the motor. When they first start to go you'll lose speeds one at a time until finally all that's left is high speed.
