Old 10-24-2005, 05:39 PM
3SBlkStreak's Avatar
3SBlkStreak 3SBlkStreak is offline
Synthetic vs. Regular Oil. Help!
I'm getting ready to do my first oil change in my 3000GT an i was wondering if I should synthetic or regular. Ive heard if you change from synthetic to regular it could be hard on your engine
Old 10-24-2005, 07:02 PM
2old 2old is offline
Re: Synthetic vs. Regular Oil. Help!
Do a search... It's a re-occurring subject... Most of it was covered in this thread:
http://www.automotiveforums.com/vbul...=457132&page=1
Old 10-25-2005, 04:13 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
You don't want to switch to synthetic. The possibilities of leaks for the age of your engine are a lot more probable. Just stick with a good petroleum based oil.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-25-2005, 09:06 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
i;ve used full synthetic how does it hurt the engine?
Old 10-25-2005, 11:42 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
synthetic oils are much finer than petroleum oils, so the synthetics will get in all the tiniest crevices that the petroleum oils might not get in. and so, as the car gets older, if you switch to synthetic, then you're more likely to have some leaks, whereas the petroleum oil wouldn't leak.
so synthetics won't "hurt" your engine directly, but if it is thusly more prone for leaks with the switch to synthetic, then if you leak enough oil, there's inherent damage that can occur due to lack of lubrication.
that's the basics, but i'm sure there's more to it and someone will chime in the the details (2Old?)
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-26-2005, 01:20 PM
It's actually the cleaning action of the detergents that cause the leaks but Linebckr pretty much summed it up and a good portion was covered in the thread I linked to.
I was just reading it over and I guess I should point out that as long as your engine is not leaking oil or built in the 1980 or earlier, Synthetics are by all counts better then Conventional oils.
I have a 92 Dodge stealth with 180K kilometers on it (I guess that would be 120K miles) and have been using synthetic for as long as I have owned it (6 years) and I haven't seen any leaks and it's still running strong.
I don't really want to sound like commercial or repeat information so I won't go into details unless someone asks a specific question...
