Old 10-24-2005, 04:27 PM
oldnanacc oldnanacc is offline
how to install radiator fan module?
I've taken the plastic guard off .I need to know how to unplug old module?
Old 10-25-2005, 01:05 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: how to install radiator fan module?
Are you referring to the Constant Control Relay Module mounted on the radiator core support? The box with a 24-wire connector going to it?
If this is the one you're referring to, I believe there is a bold in the center of the connectors (may be covered by wires) that you need to loosed, probably an 8mm or 10mm. Once the bolt is loose, the connector should be able to be pulled out of the CCRM module.
-Rod
