Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-24-2005, 03:40 PM
Speakeasy Speakeasy is offline
Question 98 Intrepid 2.7 exhaust smoke from exhaust , not only when being started in the morn.
If anyone can help me It would be greatly appreciated!
I have a 98 intrepid 2.7.. For some weird reason my exhaust has been spewing out smoke...not frequently on and off..if this is a problem I want to find out now, just in case it gets worse.
Old 10-24-2005, 10:49 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 98 Intrepid 2.7 exhaust smoke from exhaust , not only when being started in the morn.
what color is it? If it's blue, you have oil entering your combustion chamber and that is due to worn valve guide seals, that's a common problem on this type of engine. If it's black, you're running rich, i.e. using too much fuel. That can be caused by bad injectors, clogged air filter, etc. If it's white and smells sweet like antifreeze, you have a head gasket failure caused by coolant leaking into the cylinder(s). If it's just a light mist, it could be something small as condensation, which is normal and no real need to panic. Hopefully this helps.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-25-2005, 12:23 PM
Thanks, that does help a great deal..it narrows it down.. The smoke is white..I've had folks tell me either the head gasket or the condensation thing..it's always good to get more than one opinion..
It's funny I like this car, I haven't really done any upgrades, if you have any recommendations..If it will help me further down the line...ya know..
Thanks again!!
Old 10-25-2005, 10:29 PM
if you are not already using it, I'd suggest you start using synthetic motor oil. But there are a few factors to take into consideration before you use synthetic. First, make sure that you don't have any oil leaks & second, if you have over 100,000 miles, I wouldn't recommend using it because you could have seals that are starting to go bad. The reason why it's so important to know that ahead of time is because synthetic is on average $5 a quart. As far as any other upgrades, you can get a K & N FIPK for around $130 and that'll give you an extra 5 HP. There aren't too many aftermarket chip companies that I know of as of yet, but I'm sure that if there's a big enough demand, that will soon change.
Old 10-26-2005, 11:13 AM
I appreciate your help!
Thanks for the advice, very much informative.This site is off the chain!
Old 11-02-2005, 01:12 PM
cash2005 cash2005 is offline
Re: Re: 98 Intrepid 2.7 exhaust smoke from exhaust , not only when being started in the morn.
I have a 2002 Intrepid with 60K miles. Is this a good time to go for the synthetic oil change and if so what are its advantages? Thanks!
Old 11-02-2005, 10:57 PM
sure, as long as you don't have any oil leaks, you should be ok. I just changed the oil on my '02 Intrepid and I have 69,000 miles on mine and still use synthetic, runs like a charm w/ no leaks and no problems whatsoever. Synthetic is a designed to take higher temps where conventional motor oil would fail. It reduces sludge build-up, friction and heat, the 3 main factors that lead to engine failure. It also doesn't wear out as fast as conventional oil so, theoretically, you can go up to 10,000 miles before you next oil change, but I wouldn't recommend that and never will. The big disadvantage to sythetic is that it's expensive ($4-$5/quart). Last Friday, I changed my oil and spent $35 for oil (5qt.) and filter. Expensive, yes compared to conventional, but it gives your engine added protection compared to conventional. You'll see a lot of marketing nowadays for synthetic blends, those are garbage and from my experience are a complete waste of money. It's either conventional or synthetic, in my opinion, no in-between nonsense.
