Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-24-2005, 02:10 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Shifting Problems Good God!
Recently I back ended an suv goign about 40 mph due to break failure...
anyways aside from the body damage I noticed that the shifting was really tight afterwards...
I had it toed to a body shop and they told me it doesnt shift into any gear at all and that it is stuck in a gear...
What does this mean...?
How serious is this...?
How can it be fixed...?
If anyone out there knows please get back to me...
thanks!!
Old 10-30-2005, 03:36 PM
utsagq utsagq is offline
Re: Shifting Problems Good God!
about 3 yrs ago, i had an integra gsr that i backed into a curb at about 15 mph with and i had the same problem. the shifting got terrible and it felt like it was grinding gears the whole time. it turns out that when i backed into the curb, it nailed my exhaust up into my engine and pushed against the gear box. sounds like the same kind of thing goin on with you. al they did was put it on a lift and use a press to pull it backwards into place and take the pressure off of my engine and what not. it was cheap and easy for the shop to do. good luck!
Old 10-30-2005, 05:07 PM
Well that sounds good! Where is the gear box exactly located?
Currently they are fixing the body, it should be done in about 5 days... The tranny prob. is a different story... I hope it as is easy as yours was to fix...
Old 11-12-2005, 12:41 AM
laser apexi turbo laser apexi turbo is offline
my friend had a rpoblem lieok that in his talon tsi awd, it stayed in the same gear nomatter where u put the shifter. problem was because one of the pins that hold the shifter linkage to the tranny fell out. check that
Old 11-12-2005, 12:50 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
well sounds like to me if u had brake failier ur brake lines could be be bad so that could be another easy fix bleed ur clutch to make sure it is getin fluid
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
