Old 10-24-2005, 01:38 PM
bill57 bill57 is offline
97 f150 airbag light
my lil guy and the airbag light keeps flassing 3 times then 2 then stays on...whast up?
Old 10-26-2005, 04:45 PM
2549 2549 is offline
Re: 97 f150 airbag light
I am having the same Problem in my 98. Did you figure anything out?
Thanks
Old 10-26-2005, 05:53 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Could be a code 32
If the light stays on you have a SIR problem.
Air bags can save your life or they can injure or kill you if you fool with them and do not know what you are doing.
Better and safer to get a air bag trained repair shop to fix it.
MT-2500
Old 10-26-2005, 06:04 PM
MT-2500's Avatar
AF - Advisor
I notice you have a post on dash gauges.
Did the air bag come on before or after you had the dash out? Could be unpluged.
MT-2500
Old 10-27-2005, 11:44 AM
it code 32 and the cruise dont work so its the clockspring im going to replace it this weekend
Old 10-27-2005, 06:14 PM
what excatly is a code 32? My cruise is not working as well as the flashing airbag light, but the cruise didn't go out until a good while after the this light problem started (probably 4 months apart). However iI did recieve a letter from ford about a recall for the cruise control. What do you know about this? Could they be related? My horn quit working as well and don't see any blown fuses. I am confused?
Thanks
Old 10-27-2005, 06:39 PM
MT-2500's Avatar
AF - Advisor
Code 32 is somthing on drivers side is not making the circuit.
But unless you are trained in aib bag repair find some one that is.
Good time to get the ford recall done and go from there.
MT-2500
Old 10-27-2005, 09:17 PM
its called a clock spring it takes like 3 hrs TOPS to do its under by tthe sterring column its liek what makes the electrical connection for the air bag and cruise and horn its like 80 - 100 for the part...i will let u k now how it goes...and im pretty sur ethat recall is for something else but let me know
Old 10-29-2005, 11:13 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
i have a 1992 merc grand marquis (still ford) and im about to inlightin u i had the same problem so i replaced the clock spring and got my horn and cruise back but then the airbag code changed and its saying that i have a blown internal fuse in my air bag module now with only haveing a driver side air bag theres only one module but on the f150 theres to so replace the clock spring and then if it fixs it good for u and if it doesnt post the code and ill tell u what i means code 32 means high resistance or short in driver side air bag circuit aka bad clock spring hope this helps
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
