| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
f150 battery light
Ok, here is the deal......have looked everwhere.
Driving truck at night went to use the brights and the battery light came on, took it to advance auto and tested the alternator and the battery and they said both were ok. They also ruled out a short, so does anyone have any idea what this could be? This only happens when I use the bright lights. Thank you
Doesn't anybody have a clue?
Re: f150 battery light
Later Ed |
I have had several alts and batteries tested before at parts stores and I have found it better to have them test it outside while it is attached to the vehicle so you can be sure you are running a load through them instead of actually removing the part and taking it in. I have had several batteries and alternators that they have tested and said were good but were actually bad. Also before you do that I would check all of connectoins like unclebubbles posted. Good luck.
They did output test, will have them check again and see. I'ts a 1997.
Thank you |
You guys are right, it is alternator, thank you very much.
