Where To Get Crank Relearn Done
Hi I live in the austin tx area. Has anyone had a crank relearn done around this area? How much was it? I called champion and they really didnt know what I was talking about so I explained the best I could and they said they might have to reflash the pcm.
beerbq |
Crank relearn? What was done to require this procedure?
Re: Where To Get Crank Relearn Done
Im not sure of who could do it for you. But any reputable car shop should be able to help you out. You may have to take it to the dealership. This came from Nelson Performance "New computers may need a crankshaft relearn performed. A common trouble code is P1336 (Cam/crank sensor position relearn). The procedure is very easy, however it will require the use of a TechII/Genisys or similar handheld capable of doing the relearn. Basically, the handheld scanner is connected to the OBDII port and the engine is revved a few times."
2004 Silverado Half-Ton Crew 7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block 3" PA Body Lift Yukon 4.88's with Auburn LSD Xentec 6500k HID lows, Silverstar Ultra brights Wade in channel window vents Covermaster Top Flowmaster 40 series, dual outs Nelson 89/91 HOT TUNE 20" MB Gunner 6's, 37" Toyo Open Country MT's Eclipse AVN6600 w/sirius and IPOD controllers Code Alarm w/ Remote Start |
