Old 10-23-2005, 11:49 PM
Rudyfastcat Rudyfastcat is offline
92 Chevy C1500 W/Rough Idle
I have a 1992 Chevy C1500 w/ 4.3L(V6) and manual trans.
My truck just developed a rough idle this week .
My problems originaly started when my EGR went bad and I replaced it about 2 weeks ago.
I replaced it and the solenoid with an after market one (Auto Zone) and found that the problem got worse I eventually bought a AC Deloco OE EGR & solenoid and all seemed well until this week when I started feeling the idle a little rough,
Now I have gone ahead a replaced the Dist.(cap & rotor too), plugs, wires, coil and IAC and still nothing has changed. I have even chaged the sparkplugs and wires twice just in case and still nothing has chnged.
I still have good power and I do not notice any problems while driving just while sitting at idle or in nutral (no boging)
Is there somthing that I am missing ???? Please help
Old 11-01-2005, 09:02 AM
slythee slythee is offline
rough idle
I have a '93 and have experience this also. Here's what I've noticed: The idle is smooth when the engine is cold. I also notice the volt meter sitting on about 13.99 volts. However, when it heats up, the volts meter drops and the rough idle gets worse. I wonder if this is an charging problem because the volt meter bounces when I turn on my blinker or witpers. I have also replaced the cap, rotor, plugs, & coil, but you mentioned the EGR. Where is this because I don't find one on my truck?
Old 11-01-2005, 02:49 PM
Talking Re: rough idle
The EGR is located right behind the TBI just in fron of the dist. .
It has two bolts that mount to the intake
Old 11-03-2005, 02:25 PM
Re: Re: rough idle
I looked last night and can't seem to see what exactly is getting recirculated. It seems to be hooked up to itself. My Chilton Manual sucks and doesn't show a good veiw of how its connected. Do you know where I can find this?
Old 11-07-2005, 12:07 PM
Re: Re: Re: rough idle
I replaced the EGR and finally figured out it was all hooked up correctly.
Still runs rough. Maybe I'll replace that thing distributer.
Old 11-07-2005, 11:19 PM
jwb318 jwb318 is offline
Have you checked to see if you have a weak coil ?
Old 11-08-2005, 07:52 AM
Re: 92 Chevy C1500 W/Rough Idle
I replaced it with a new one from MSD.
Old 11-08-2005, 08:46 AM
offroadjoe offroadjoe is offline
my 88 4.3
hey guys i got a 88 4.3 manual to.. and yes my idle is rough i donno what it is.... the hole truck shacks lol guys i think v8 is the way to go lmaoo... umm i always wanted to fine a guy with a 4.3 standard like mine cuz when i drive lik ein first or whatever and tap the gas something hits its as if the gears slap together or something .. like if i keep tapong the gass its fucked just keeps slapping .. i dont no how to explain it but if anyone understands than please help lol .... thank you
Old 11-08-2005, 08:58 AM
Re: my 88 4.3
Slapping is probably bad u-joints, wore out rearend, or broken transmission mount.
