Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 10-23-2005, 10:43 PM
MyNameIsRandom MyNameIsRandom is offline
Need help on amplifier wiring
I just got a wiring kit, and I was trying to connect the power cable to the battery from the amplifier. I Have a Honda accord 1989, and i cant find where to feed the power cable through from the passenger footspace, i couldnt find anything. There werent any holes to feed the cable. If any of you know were to feed the cable into to get into the engine area, i would really like to know where the space is that goes from the passenger footspace to the engine area.
Old 10-24-2005, 12:18 AM
TurboLaxx's Avatar
TurboLaxx TurboLaxx is offline
Re: Need help on amplifier wiring
I have a 2000 Civic and i ended up drilling a hole for mine. Does the kit include a firewall gromet? If not go to Lowe's or Home Depot and get a rubber gromet BEFORE you drill any holes in your firewall. Then drill the hole so the gromet just fits like a glove. Run the cable and seal it with some type of sealer and you're done. Nice thing about making your own hole is you get to choose where the cable goes and you might run less cable length.
Old 10-24-2005, 06:59 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
I'm not very familiar with the older accords but just look at your firewall and find an existing grommet and either push it aside to run the wire or push the wire through it. I know on EF's there is a small hole right near the battery tray that a power cable will fit nicely through. But drilling should be your last option. Take some time to look around and you'll find a good place.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-25-2005, 02:16 PM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
don't just limit your lookin to the area by the passenger foot area. you may be required to use more wire, but if you find a spot by the friver foot area that is a perfect are then why not put it there
Old 10-25-2005, 10:31 PM
Ok thanks thats good, i found another area, im gonna go into my auto class and ask how to take the fender off, and il try and find some hole so i can see where to feed the cable through, then im good, if not il just go through an existing grommet
Old 10-25-2005, 10:40 PM
ummm, why do you need to take the fender off?
Old 10-26-2005, 06:26 PM
NA is Best!
The fender idea is not so good. If you run it through there and then through the door jam, you risk fraying it and possibly shorting it out. If you're in an automotive class, just ask one of your instructors to help you find a good grommet.
Old 11-01-2005, 08:04 PM
Pavlo's Avatar
Pavlo Pavlo is offline
I used to run my power wire through the door jamb, but i could barely sleep at night after doing such a lousy job,so I did find a hole and now my wire goes through the hole in the firewall sharing it with an tube that gets rid of water from AC. I am pretty sure that if you look enough you will find a nice hole, just keep looking.
Through a doorjamb is like doing it with a slut, unsafe but easy. Drilling is like doing with a fat chick, might be dangerous but realtively easy. Finding a nice hole is like finding a perfect women, the hole is nice and everything goes very smooth.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 11-01-2005, 11:24 PM
TurboLaxx's Avatar
LOL i love your comparisons. So true in fact.
Old 11-18-2005, 08:06 PM
coll9947's Avatar
coll9947 coll9947 is offline
On EF civics there is definitely a hole near the battery tray that is perfect for running power wires. What I discovered when I first ran power wire on an EF is that the hole is much higher behind the dash than I thought, so I recommend pulling back the carpet and getting way up under the dash with a flashlight and have a friend feed the wire.
2000 Honda Civic LX sedan
1991 Honda Civic LX sedan
-= [email protected] =-
Old 07-15-2007, 05:36 PM
jackmannequin jackmannequin is offline
i have the same question. except that i found the grommet on the driver side, but dont know how to take it out. it looks like the wires are pretty packed through that hole and it doesnt look like a power wire would fit.
thanks
