I have a 1990 Jeep Wrangler with a 4 cylinder. I'm having a problem with stalling out while driving and not being able to start it back up. If I wait about 20 minutes it will start back up. It also spits and sputters at about 1100 rpms? If anyone has a clue i would appreciate the help
Thanx, Don |
It sounds like for have a fuel problem. More than likely your fuel pump is about to crap out. Usually on these jeep the pump will work great at times, and other times it won't supply enough fuel. If you have a pressure tester I would hook it to the fuel rail and check start up and wide open throttle. At idle I think your should have about 40 psi and @ wide open throttle you should have 60-70 psi. I think.
1995 Jeep Wrangler 3 1/2" lift 33x12.50 tires 4.5L stroked I-6 Bored throttle body & Cold Air Intake Jet Chip Stage 2 Jet Thermostat Colorado Off Road Rig!!! |
Re: stalling problem
thanx ill give a try and let ya know
