Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-23-2005, 07:21 PM
page1 page1 is offline
ecm clips
i am having problems with the two out of the three clips are broken and if they move the slightest bit the car will stall so sometimes my car will randomly stall out idleing or driving. It is a 1998 jgc 2wd does anyone know how i can get new clips or fix the problem. Even when you pull the slightest bit on the main wiring harness coming from behind the motor if you pull it from the ecm it will stall almost imediatly. the clips are the ones that hold it steady onto the ecm. any help would greatly be appreciated
Old 10-24-2005, 08:59 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: ecm clips
what clips are you refering to?
the only thing that holds the wiring harness to the ecm is the bolt in the center of the connecter. there are clips on this connector but they just holt the black protective casing (prtects the wire) onto the connector. If you wiggle the connector and engine shutters or stalls then there is probably a broken/bare wire at the ecm under the cover (black protective case).
Old 10-24-2005, 11:27 PM
Re: Re: ecm clips
i do not see the 8mm bolt on the black case there are little metal tabs folded back to hold it together and two of them holding it to my firewall.the latched are broken that hold the plugs into the computer there are three of them and i cannot figure oout how to fix them
Old 10-24-2005, 11:46 PM
Re: ecm clips
Is there anyway you can get a picture of this and send it to me, so I have a better idea of what your talking about.
Joe
[email protected]
