Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-23-2005, 05:28 PM
getfreshco getfreshco is offline
what to do?
okay i just moved to the east coast (Maryland/ washington Dc)...and i just relized that my car has never seen a real winter with snow and all...California its whole life....what do i need to do to get it ready?
Old 10-23-2005, 08:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: what to do?
Change the oil to something like a 10w30 - 20w50 if it has wear on it - stay away from 10w40.
That's pretty much it, that and a box of tire chains.
Old 10-26-2005, 05:17 AM
copcarcrzy copcarcrzy is offline
Re: what to do?
take the car to a dealer, or mechanic you trust and have them, check the coolant, they will be able to tell you, how cold the coolant is protected for. ex. -20 or -30 below. if its been a while flush the system.. new blades help, and a tune up also will help if its been a while. have the defroster checked and the heater.
Old 10-26-2005, 02:21 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
make sure you clean it often, or the rust will kill it
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-26-2005, 06:07 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: what to do?
Undercoat it!! *Get a Rust Evader corrosion contol unit*. Wax the hell out of it.
***And heres one for yah... this works VERY VERY well at keeping the rust away from rotting out crutial parts like brake lines, gas lines, floor pans, nuts bolts, etc. Take thick grease (not food grease), preferably Long Term Grease and get a lot of it. Then get a rubber glove and take the grease and spread it along your floor pans, all over your brake & gas lines (especially where there's clips and areas touching the chassis or axel) and anywhere else under the car that you dont want to rust. Believe me I found this out accidenty when there was some grease on my A-frame and I wiped off the grease and underneith there was absolutely no rust. So I decided to just cover the entire bottom of my car in grease, even the areas that have already begun to rust. Since then the car has seen 2 winters and the rust hasn't gotten any worse.
I've also noticed on other Caprices that rust likes to creep up from behind the chrome trim around the wheel wells. I took off the crome trim, cleaned behind them out and greased the inside of the trim where it wouldnt be seen, but will still prevent my car from rotting. So far so good, 3 winters total and my car is nearly rust free (besides areas of the underbody that had begun to rust before I got the car). As for the body itself, its completely rust free. If possible I'd want your car to remain in its good condition as well. I will be listing a post tonight with a bunch of information on rust removal and prevention. Check it out.
