Old 10-23-2005, 01:43 PM
tat2man67 tat2man67 is offline
oil leak
i have a 1993 blazer tahoe with the vortec motor. it runs fine and sounds good. the problem is when i tach it up it leaks out of the dipstick tube and around the sending unit threads. there is also a lot of smoke coming out of the airbox when i disconnect it from the intake. any help would be great. would hate to junk the truck. thx in advance.
Old 10-23-2005, 02:22 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: oil leak
Have you checked your oil level? Could there be poissible too much oil or maybe the wrong weight oil in there?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-23-2005, 04:36 PM
Re: Re: oil leak
yes i did and the oil is fine and so is the level.
Old 10-23-2005, 05:28 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: oil leak
I would also check to make sure that your PCV system is up to snuff. A failure here could blow oil out of the engine. I have to get off my duff and replace a cracked boot and a not so good looking socket seal on top of one of the valve covers.
Old 10-23-2005, 06:30 PM
Re: oil leak
already checked that and it has good suction. im running out of ideas
