Old 10-23-2005, 11:29 AM
Purple_Haze Purple_Haze is offline
Low Washer Fluid Lights
I remember that somebody said that if you switch your gauge cluster from a Hummer or Escalade, you will get that annoying Low Washer Fluid Light on the Message Center because our trucks don't have that sensor.
Mine does exactly that. It comes up once in a while-the washer container is full. But my gauge cluster is stock. At least that's what i have thought, i bought the truck 4 months ago.
Old 10-23-2005, 03:02 PM
LongIslander26's Avatar
LongIslander26 LongIslander26 is offline
Re: Low Washer Fluid Lights
If your guage cluster is stock (As in "Came with the truck from the factory"), and it's telling you the fluid is low, then it sounds to me like you have that sensor. If the truck is only 4 months old, take it to the dealer and have it looked at under your warranty.(Bad sensor, loose wiring, etc) If it IS an aftermarket cluster, and you don't have the washer fluid sensor, then pull the cluster and remove the bulb. If it's the "Message center" I'm thinking of, you may want to ask at the dealer if they can turn that function off with then Tech 2 scanner. Sometimes new clusters have to be programmed to work right with the PCM and the body control module.
ASE Certified Automotive Technician
ASE Certified Service Consultant
ASE Certified Parts Specialist
Employed at an Independent Shop
Vehicles:
2005 Silverado LS Crewcab 4X4
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-23-2005, 08:45 PM
Sorry i think i did not make my self clear, and did not post enough info, the truck is a 2000, that light did not came on before, i can not disconnect it, its a message center LCD. WTF is going on?
Old 10-23-2005, 10:05 PM
Sometimes new clusters have to be programmed to work right with the PCM and the body control module. But seeing as how it is an intermittent problem even when the washer is full, I would suspect loose wiring, or the level sensor is on its way out. Try a wire wiggle test with the truck running and someone in it to watch the dash. Or, you can remove the washer reservoir, empty it out, and rinse it out real good with clean water an reinstall it, in case the sensor is gooped up.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 10-23-2005, 10:44 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Well i don't know about anyone else, but i have the low washer fluid level sensor.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 10-23-2005, 10:53 PM
i guess, i better go and see if i have one too.... lately too much sh*t has been coming on my dash. The salesman from the place i bought the truck was Russian, he had a strong MOB type accent:PPPP not to offend anyone of course...!!! I love my truck.
They offered a powertrain warranty. They wanted 12000$ for it, i came in with 10000$ in 20$ bills, lol.. and told them, its either 10k or im walking out. They sold it, anyway, what im trying to say is... that my diff is whining:P and it wasnt before-Did they know? who knows..
will check for the sensors... where to look for the washer fluid sensor?????????????
Old 10-23-2005, 11:54 PM
kenny-1907's Avatar
the sensor is in the washer fluid resivior
6" Pro Comp lift
K&N FIPK GENII
Old 10-24-2005, 10:14 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Re: Low Washer Fluid Lights
I do too and mine is a 99.
*Under Construction - New sig to debut*
Old 10-24-2005, 10:19 PM
Smile
yeahh, it seems logical that the sensor would be in the washer reservoir for some reason i did not think of that;P
Old 10-24-2005, 10:24 PM
You'd be surprised how much crud gets into those things. You may want to remove it and rinse it out with the garden hose, and then refill it with fresh washer fluid. That just might free up the sensor to stop giving false readings. Check the electrical connection and the wiring too while you have it out. Otherwise, you may just need a new sensor, and they're real easy to replace.
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
