Old 10-23-2005, 10:16 AM
1995camaro3.4 1995camaro3.4 is offline
3.4 sawp to 4.3
my camaro has almost 200k on it so i dont think its going to last much longer i hav an 4.3 s10 motor and tanny with about 30k could i put that in my camaro what all would i would i have to do so that every thing works fine or should i just get new 3.4
thanks ahead
Old 10-23-2005, 10:21 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: 3.4 sawp to 4.3
what tranny do you have with the 4.3? Its definetly possible and well worth it if you already have a 4.3 lying around.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-23-2005, 10:28 AM
i think its a nv3500 i cant think of it off the top of my head but do u no if i have to do anything to the car or can i just sawp them and go
Old 10-23-2005, 11:01 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 3.4 sawp to 4.3
that 4.3 tranny probably isn't set up for an f-body suspension (torque arm and mounting locations) you'd either have to find some way to modify it to fit or perhaps the tranny from the 3.4 will fit the 4.3.
Old 10-23-2005, 04:28 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: 3.4 sawp to 4.3
Thats the first time ive heard of a 4.3 in a camaro. Its a good idea. They should of come like that from the factory.
Old 10-23-2005, 04:36 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
no the 4.3 will not bolt to the 3.4 tranny.......the 4.3 is a 90 degree motor and the 3.4 is a 60 degree....different bolt patterns
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 10-23-2005, 05:28 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: 3.4 sawp to 4.3
I believe putting the 4.3 in will take same modifications as putting a 350 in (since they are the same, just minus 2 pistons).
Also, what year of s10 is that engine comming out of?
If its a later model 95+ i believe it would have the 4L60E tranny, or if its older, it will have the 700R4
Good luck
-Ryan
Old 10-25-2005, 12:49 PM
scoobytuff scoobytuff is offline
Re: 3.4 sawp to 4.3
That would be a good swap without a lot of clearance issues. Not to mention the power potetial for the 4.3.
