Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-23-2005, 07:49 AM
notenoughmoney notenoughmoney is offline
Send a message via AIM to notenoughmoney
need some advice about check engine light
My check engine was on and I i went to a mechanic and he said that it was the EGR Flow sensor(I think that is what he said). He said he reset the codes and drove it around the block and he said that the light didnt come back on so it should be fine. Well now the light is on. I really cant afford a 500 dollar job could anyone tell me how much the part should be and does it need to be fixed right away?
Old 10-24-2005, 01:25 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: need some advice about check engine light
repull the cel to see if it is the egr again. the egr cel can be caused to plenty of things that need to be checked. but, to make ease of what people are looking at, year, make, and model would be nice assuming your car is stock.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-24-2005, 01:33 PM
thanks for the response
1997 Civic (HX I know crap) Stock except some body work
Old 10-24-2005, 06:19 PM
AF - Advisor
clean the areas around the egr and inside of the egr valve with carberator cleaner, or you can just replace the valve. reset ecu and see if that solves the problem.
if that doesnt work, then, your going to have to check the vacuum lines to the egr valve, the egr solenoid, and the egr lift sensor. but, before coming here, you should do the above first.
also, your mechanic just pulled the code or he already actually checked the egr system?
Old 11-02-2005, 03:26 AM
CrxFreak91 CrxFreak91 is offline
check the o2 sensor too that will cause the egr to go bad
