Old 10-22-2005, 11:52 PM
jgaona002 jgaona002 is offline
1996 S-10 Won't Start
My S10- has 285,000. The current problem is as follows:
I found the starter to be bad. Replaced it. Now when I turn the key nothing happens. Rechecked all connections. all are properly connected. The only sound that is made when the key is turned is the sound of the relay switch, nothing else. Any sugesstions. Thank you in advance.
Old 10-23-2005, 12:05 AM
nynewyorkcool nynewyorkcool is offline
Send a message via Yahoo to nynewyorkcool
Re: 1996 S-10 Won't Start
did you make sure to install the shim??i know this is a bad rule of thumb but it has worked for me many times with starter instalation....tap it LIGHTLY with a tool
Old 10-23-2005, 12:16 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Re: 1996 S-10 Won't Start
tap it LIGHTLY with a tool[/quote]
hey, if it works when your in a spot there's nothing wrong with it.
When your fuel pump is going just banging on the fuel tank will often get you going again too.
