Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-22-2005, 11:31 PM
sharpx sharpx is offline
fog lights...
Do the fog lights only come on when you press the button if the running lights are on in the day time? When I turn my headlights on and press the "FOG" button, nothing happens.
Old 10-23-2005, 12:55 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: fog lights...
DAYTIME - if the headlight switch is all the way in you cant run on the fog lights.
Pull it out once then your DRL's are still on and you can turn your fog lights on.
Pull it out once more, now your low beams are on and you can turn on your fog lights.
NIGHTTIME - no matter where your headlight switch is you can turn on your fog lights.
Old 10-29-2005, 07:23 PM
Re: fog lights...
Mine don't work. I think it may just be the switch. The light that says "fog" comes on with the gauge lights, but when you push the button, the actual light on the button doesn't ever come on. (and obviously the foglights don't either.) Hm!
Old 10-29-2005, 07:24 PM
bigrod118's Avatar
Re: Re: fog lights...
well even tho you probably already checked it... fuse.
