Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-22-2005, 09:53 PM
98 jimmy 98 jimmy is offline
wheel hub replacement
My 98 Jimmy has a humming noise comming from the front right wheel. Can someone give me some instructions as well as tools I'll need to replace the wheel hub?
Old 10-22-2005, 10:17 PM
JimmySLS's Avatar
JimmySLS JimmySLS is offline
Re: wheel hub replacement
Hello 98..I would suggest getting a haynes manual or search through this forum.There are some how to's listed through out this forum.One of the tools you will definately need is a 36 mm socket for the axle nut to release the hub...Good Luck
2001 Bonneville SLE "Bella Donna"..... K&N Filter, Ceramics pads on front and rear,XM radio.. 130k on the clock...All the bells and whistles...check my car out at [url]www.cardomain.com/ride/2058777... R.I.P Bella Donna..wrecked on 05-08-07...
Old 10-24-2005, 04:01 PM
danfman danfman is offline
I did that job last year. You can borrow the a hub socket set from any autozone or larger auto parts store. You will also need a 3-jawed chuck after all the bolts have been removed to pullthe hub off the spline. Good luck
Old 10-24-2005, 04:37 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Nah... Simply run the nut up flush to the top of the axel and whack it a couple of times with a hammer..(don't worry, the threads will be fine)...
Then when you remove the 3 18mm bolts on the back of the knuckle, simply use a hammer tapping repeatedly on each side evenly (whack twice, go opposite end whack twice again, repeat as needed) the hub assembly will start to seperate from the knuckle...
