Old 10-22-2005, 09:12 PM
pompadourdaddy pompadourdaddy is offline
Question 92 cavalier abs light
my abs light stays on, and the brake light blinks, what could it be?
Old 10-23-2005, 02:27 PM
G0ldRush's Avatar
G0ldRush G0ldRush is offline
first check for oil missing or leak second check brake pads third check for unplugged terminal at caliper and the big plug near the wipers motor fourth check for air in the system by bleeding directly from the abs bleeder dont forget when bleeding everytime you press the pedal leave to the floor afterwards closing the bleeder to prevent pumping some air repeat that untill you get a satisfying outpout continoustly liquid.
Den
Old 10-23-2005, 03:28 PM
Re: 92 cavalier abs light
ive checked all that, could it be that the abs relay is out?
Old 10-24-2005, 11:01 PM
G0ldRush's Avatar
http://www.rockauto.com/ref/ACDelco/...html?PT374.jpg
Old 10-25-2005, 12:36 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: Re: 92 cavalier abs light
A good posibility, I would get another relay from a junk yard though, some new ones are outrageous!
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 10-29-2005, 03:29 PM
dptw22 dptw22 is offline
abs light
i had the same problem and i changed my brake switch.
good luck
Old 11-07-2005, 09:21 AM
AssDust AssDust is offline
yea man, its the relay. The relay is located on the firewall in the left side.
