Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 10-22-2005, 09:37 PM
qman4467 qman4467 is offline
Send a message via Yahoo to qman4467
95 Achieva
i started getting a lound noise and some vibration from the front end. kind of sounds like bearing going bad, but lower in pitch. Could this be a CV joint? Car has lot of miles with all original fron end except struts and brakes.
Old 10-23-2005, 07:56 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 95 Achieva
This could very easily be a CV joint going bad although you could also have a bearing issue as well. When do you feel the vibration? If it is only with braking check the rotors. If it is high speed around 50-70mph then it is probably the CV joint. If it is a constant noise but only intermittant vibration then it is probably a bearing.
You may also want to consider having the tires rebalanced as this can also cause a vibration in the front end.
Old 10-23-2005, 10:53 AM
Re: Re: 95 Achieva
Tires were just balanced. The noise appears at about 45-50 mph and is louder and pitch changes when making left turn. Above 50 noise is same - no increase. Right turns have no effect on loudness or pitch.
Old 10-23-2005, 03:23 PM
Pontiac Guy
Re: 95 Achieva
At 40-55 does the noise start or is it there all the time? I suspect a wheel bearing is bad since it is louder when you turn left. Although I would have the CV joints checked since they mimmick wheel bearings. Not a definitive answer to your question but without actually hearing the noise difficult to diagnose.
