Old 10-22-2005, 08:12 PM
TonyP TonyP is offline
Check Tire Pressure Light
Check Tire Pressure Light won't go out on my 99 grand Am GT. Tire pressure is fine. Any suggestions?
Old 10-23-2005, 12:26 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Check Tire Pressure Light
Hold down the red "reset" button in your fuse panel on the driver's side dash for 10 seconds. Should do it.
Old 10-23-2005, 08:58 AM
DigitalQuirk's Avatar
DigitalQuirk DigitalQuirk is offline
It could also be indicitive of a possible problem with a wheel bearing.
Old 10-23-2005, 09:55 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
i didnt know GAs had the low air light, I knew GP had them. Learn something new everyday........
1999 Grand Am SS 3.4 OHV
Old 10-24-2005, 05:59 PM
Re: Re: Check Tire Pressure Light
Tried it but light started blinking and now is still on. It started after I fixed a leak in a tire. All tires are now fine.
Old 10-24-2005, 06:17 PM
Ridenour's Avatar
GranddAmnit
I think the ignition needs to be in either the "Accesories" or "On" position for it to work. Try both.
Old 10-24-2005, 07:16 PM
quadkid quadkid is offline
just did this on mine. put the ignition to ON, press and hold the reset button mentioned above until either the check tire or check oil light blinks, if the check oil blinks push the reset again and it should switch to the check tire light. hold the reset button for a couple seconds and it should shut the light off.
Old 10-29-2005, 09:16 AM
Worked great except the first thing that blinked was the seat belt light, the pressed the button to the oil, then the tire pressure. Thanks
