Old 10-22-2005, 07:41 PM
diamondzen diamondzen is offline
Clicking sound when I turn right
OK, I did a search and got a few ideas, but please help guide me along if you can.
When I turn right and accelerate I can hear a clicking/popping sound. Nothing when I turn left OR if I let off the gas.
Ideas? I can do most any repair (I even did the notorious timing belt/water pump issue).
Thanks!
Old 10-22-2005, 07:50 PM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
Re :Clicking sound when I turn right
Very good chance it is something in the front brakes, or CV joint. A visual inspection would be in order. If the boots on the CV joints are cracked or torn I'd suspect that - otherwise take off the front wheels and have a look for worn pads or loose/worn brake parts. If all that checks out it could even be a wheel bearing. 10-1 though with the sound you describe it is probably the CV.
Hope this helps!
Old 10-22-2005, 08:06 PM
waltham41 waltham41 is offline
Re: Clicking sound when I turn right
Leave the vehicle in park, jack up the front end and turn the tire back and forth, watching the knuckles (boot areas) of the CV joints and watch for excessive play. Mine had a lot of play in them and when I took them off one of them pretty well was crunching itself to pieces on the inside even though it wasnt making any strange noises.
Old 10-23-2005, 07:14 AM
Mailt4 Mailt4 is offline
It sound like my,
If it clicking/noise only when you TURN AND ACCELERATE and no noise when you go straight or turn with out accelerate then that is your CV joints, look into your right CV joint, inner one, whether the boot is good or not, pop it and check to see if any grease left in it, chances are it dry, if it dry, remove the entire shaft assembly to see if it rebuildale,
Most of the time, these CV shafts are rebuildale, I’ll walk you throu if you need.
Mai
Old 11-02-2005, 10:20 PM
mrlong mrlong is offline
Send a message via ICQ to mrlong Send a message via Yahoo to mrlong
You might check your strut bearing plate. That's what I've tracked my noise to after checking sway bar bushings, ball joints and CV joints.
